1 - 8 of 8 Posts
1 Wheel Peel
Quick question.
With the programmer you can turn off the rear o2s. Does this "remove" just the post cat ones or both the pre and post cat sensors
Not A Regular Member
It's been a long time since I used my tuner but I don't remember seeing anything for O2s. So unless I just missed it, I think you have to have a custom tune written to turn off O2s.
It only removes the post cat ones. You need the pre-cat ones for your ECU to determine the correct Air/Fuel ratio.
With a newer SCT firmware that has to be done by whoever creates the tune itself and is no longer a user changeable option.
Its on there under the egr on/off
Interesting, from everything I've read the newer ones don't have the option anymore. I'll have to take a look on mine sometime.
1 Wheel Peel
I'll have to check to be 100percent but taking the cats off didn't setnoff a light eithrr
It took the downstream off when I got the tune from AM, but dont you need the upstream ones. :confused:
MOAR BOOST
The front 02's you need, they let your ECU know what your A/F ratio is like. The rears just say if you have cats or not.
EGR can be turned off with a tune also.
1 - 8 of 8 Posts
