1 - 5 of 5 Posts
So if running a higher octane gas doesn't increase hp, how does using a 93 octane tune help performance? Is it just more aggressive due to the higher resistance to detonation?
timing maybe and other parameters thats in the tune to bump the power? someone may chime in
The only thing higher octane fuel does is burn in a more controllable manner. This helps reduce the risk of detonation (or knocking). Many factors contribute to detonation including IAT, air/fuel ratio, timing, etc.
With a performance tune the air/fuel ratio, timing and other parameters are set more aggressively than your stock tune. A side effect of this is increased risk of detonation. The way to counteract this detonation risk is to run higher octane fuel.
In other words, the extra hp from a performance tune comes from the tune. The higher octane fuel is simply to keep your motor in one piece.
Check out this article for a more in-depth explanation of detonation and octane: Detonation Explained
1 - 5 of 5 Posts
