i was debating on whether to get gears or a tuner first. well i decided on a tuner, however i really like sct xcal 3 but all the shops around here only use diablo. should i be ok with getting the sct or should i get the diablo? this is just gonna be a bolt on car with 100 shot later on
Ive used them both. They both have ups and downs but I would go with diablo simply because thats what the people in your area use. On the other hand.
Sct is simple to use, loads faster than diablo, no hitting yes, yes, ok, continue, etc bs and waiting in between and
doesnt seem to lock up in the middle of using (read below). Used it for about a year no problems at all.
As far as diablo goes its simple to use as well, seems to me it has a bit more end user adjustability, easier to use, and best of all it has tons of live data viewing options. On the other hand I found it to be slow compared to the sct x3. Takes a bit longer to load tunes, seems to lock up, and i ONCE had it lock up on me during loading the tune...that didnt work out very well at all to say the least, and this was in the matter of about 2 months. I havent touched the thing since.
If you need a dyno tune, need to go somwhere local etc then the diablo is best as said above. If youre just going with simple bolt ons etc I HIGHLY recommend getting the sct x3 and getting an email tune from vmptuning.com. When I ran na with cams and a few bolt ons they did an email tune for me that was spot on other than 1st gear held for a bit too long if I was rolling through a parking lot etc...which is no big deal...It was wayyyyy better than the dyno tune i have for what im running now. Then again the place that did the dyno tune is HORRIBLE and it was a last resort to go there. Bamachips here I come (hopefully within the next 2-3 months).
