1 - 10 of 10 Posts
hi you can call me mater
Does the downpipe for a turbo go under the k member? Or up and over?
03cristian
But I'd like to connect mine to the exhaust system
03cristian
tma does his street kit over K where the motor mount is and then under the brake booster.
Will lowering the front affect the fitment?
03cristian
03cristian
The only issue it could cause would be for your catback exhaust depending on how you route it. If youre able to get the trailing portion into the transmission valley you should be fine. As far as routing it around the engine, it won't make a difference with lowering or not
1 - 10 of 10 Posts
