1 - 12 of 12 Posts
My goal with the turbo would have to be somewhere between 375 and 500 rwhp (depending on my mood for the boost that day, haha). Post color coded for those with a short attention span :D
Yeah.. I change my mind more than some change underwear, but I've got a few questions I'd like to ask to clear up some things. First off, I plan to go with the Hellion single turbo kit. I don't understand all of the jargon yet so my question is..
Is the piping in the kit 3"? I'm wondering because if so, I figured I could benefit with a 3" exhaust all the way from the Y-pipe that Hellion supplies.
My second question is (and I've read chris' thread about turbo muffler) what is a good choice for a muffler. I've got suggestions of the Dynomax ultraflow and bullet as well as flowmaster race muffler. I'm trying to see all my options, because I want to choose something that is not just loud but something that also has a great tone to it.
My third question is also on the topic of exhaust. Is there any advantage or disadvantage on a turbo setup with dumping the exhaust? I figured it would relieve some back pressure but that velocity shouldn't be an issue due to the turbo. That might be a wrong assumption, though.
My fourth and final question: what affects the turbo lag and how fast it spools? For instance, what are those upgrades that someone who knows turbos would never pass up in a kit?
Thanks and sorry for the long post.
the exhaust pipeing is almost all 3" or bigger, the charger pipes arent though, 3" is way too big, would take longer to get boost, less pipe the better, to an extent. the kit is well engineered, they used the pipeing that works best.
honestly with a turbo, i would just come down the midpipe they give you, and put a turn down on it at the end out it, no muffler, the turbo acts as a muffler, and wont be very loud at all without a muffler.
if you do want to go with a fummler though, get a borla race muffler, it sounds AWESOME, then turn it down after that.
with dumping the exhaust sooner the turbo will spool slightly faster.
thanks for the input man! about the highlighted part.. i dont understand which pipes are which.. are you saying it would be better to go 2.5" from the Hellion Y?
Read the highlighted part agian...
ok, you have a bunch of turbo pipes, you have exhaust, which dumps the exhuast out of the turbo, which is going to be a 4, or 3.5" downpipe to probably a 3" mid pipe going back, and going to 2.5" to adapt to the stock cat back.
then you have hot side, and cold side pipeing on the charge side, hot side is the piping before the IC, and then the cold side is after the IC to the intake manifold. then on the hellion single you will have a intake pipe with is 4" with a bigass filter which is the turbo air intake pipe that it draws the are in throguh the turbo with to be compressed.
i read that part, busher, but i dont know how large in diameter the Y pipe they supply is. im not talking about replacing it. i'm talking about what comes after it
alright. so you're saying at the point where a catback would connect to their Y pipe it is 2.5
yes, at that point its going to be 2.5" to adapt to a stock catback.
i would personally cut it where its 3", put a borla race muffler on it, and a turn down. it would sound ****in awesome.
then people wonder why you dont have any tips sitting in your cut outs:D
Discussion Starter #9
heh.. i like that idea. if you have any, would you pm me w/ links or something to hear that muffler
First off you should look at your other available options like HP performance.... (Cheaper Kit)
most kits have a 3"-3.5" Downpipe depending on how it is setup and tuned
most of the charge pipes and the rest of the coldside piping is 2.5" most street kits
as for mufflers, i would run stockers if you dont want loud.
dumping the exhuast makes it spool sooner because of the shorter exhuast and less back pressure
Discussion Starter #12
i have looked at hp performance's stuff before but it seems like there were some things that swayed me towards hellion as well as i think i remember reading some negative things about hp's tt kit so i figured there might be issues with the single as well
loud isn't really an issue.. i just don't want a loud "noise" with no tone
thanx for the input man, i appreciate it
1 - 12 of 12 Posts
