1 - 4 of 4 Posts
Anyone know how to wire this...the two black wires are positive and negative, the white wire is white led running lights, and the yellow wire is amber sequential turn signals both on the same strip...I just can't get the amber light to continually work while the turn signal is on. I first had the positive wire spliced to the green, and the white to the gray, the white leds were on and would fluctuate with the turn signal. I then spliced both the white and the positive wire to the green which made the white leds stay on without fluctuating. I thought this meant that the gray wire was the flasher wire so I tried to splice the yellow wire to it, but the amber lights would only sequence once right when I touched the wire to the metal and then stop even when the turn signals were on. Does anyone have any suggestions to fix this???
I tried the using the other wire but it doesn't do anything.
Usually black wires denote ground wires. Not sure why you would make one positive and one a ground, the same color.. I think the two black wires are grounds and the yellow and white are for the turn signal and running lamps. But without looking at where the wires are going and without a schematic handy I would not be sure how to hook them up. But try the black wires as grounds and use the other two for the positives on the signal and running lamps.
That's what I tried and I got the running lights to stay on, but the turn signal lights only sequence once right when I touch them to the splice and then won't sequence again even if the turn signal is on.
1 - 4 of 4 Posts
