1 - 2 of 2 Posts
Anyone know how to wire this...the two black wires are positive and negative, the white wire is white led running lights, and the yellow wire is amber sequential turn signals both on the same strip...I just can't get the amber light to continually work while the turn signal is on. I first had the positive wire spliced to the green, and the white to the gray, the white leds were on and would fluctuate with the turn signal. I then spliced both the white and the positive wire to the green which made the white leds stay on without fluctuating. I thought this meant that the gray wire was the flasher wire so I tried to splice the yellow wire to it, but the amber lights would only sequence once right when I touched the wire to the metal and then stop even when the turn signals were on. Does anyone have any suggestions to fix this???
I tried the using the other wire but it doesn't do anything.
Did you replace the factory turn signal bulb with an LED bulb?
1 - 2 of 2 Posts
