1 - 2 of 2 Posts
I have an 89 Gt and the motor was swapped for the 351w, so of course there are wiring screw ups. but anyways, turn signals dont work, hazards works, bulbs are good. would it most likely be the wiring harness for the actual turn signal switch? or something else.
PSN alphadong11
Make sure all the fuses are right and still good. Then look for the flasher. There will be 2 different flashers one for the turn signals and one for the hazards. Have your hazards going and you will be able to hear the hazards one. That's not the one you want.
On mine it was tucked way up in the dash behind the fuse box, but I have heard some of them are behind the radio and even behind the glove box. If it helps look for the same color wires that are in my pic.
1 - 2 of 2 Posts
