1 - 9 of 9 Posts
Every once in a while my turn signals stop working out of the blue they will be working fine one minute and the next time theres nothing i've had the turn signal assembly in the steering column replaced less then a year ago cause it was bad when i bought the car any ideas of anything I could check?
in the fuse box is a circular thing try replacing that or check if your hazard lights switch is loose that will do it too
has the ignition ever been replaced? a bad one will also cause this , there was a recall on them
alright the turn signal flasher will be under the steering wheel towards the back its the round one, and the hazard lights one will be behind the glove box, mine used to do that and it was the turn signal flasher got it fixed and no problems since then... hope it helps
Who Care's ... Boost It!
Check your blubs maybe, and for sure check your fuses.
your welcome man glad it helped...
1 - 9 of 9 Posts
