1 - 9 of 9 Posts
....ok so I got new side mirrors that have turn signals on the outside of em. So what I need to know is it came with a wire extention/splicer that needs to connect to the turn signals on each side. If the extention is a red and black wire, what do I need to connect this to? I really only need the right side of the car because for some reason I wired the left side and it worked, but when I tried the right it didnt. Leme kno if you can help me out...thanks
Golf Pencil Kawk Juggler
Are you tapping it into other wires or running it into the fuse box? Because if your tapping it then you can look up the wiring diagram and find out the colors needed to tap. But the fuse box should be self explanitory.
I'm tapping into the other wires....where is the wiring diagram??
The Despised Vert
to each their omn
1 - 9 of 9 Posts
