1 - 9 of 9 Posts
My 07 Gt will not start at times. Turns over but wont start. No codes and no driveability problems once it starts. I can hear fuel pump cycle.
Anybody have this issue? Car is bone stock, no recent work done.
Insomniac
Could be the pats system not recognizing the key right away, try a spare key. Could be the pcm not firing the coils or injectors
Mechanical Engineer
try WOT at start next time. I had that issue the morning after purchasing my new 06.
I'm debating if it is the race tune and colder weather causing the problems. it seems to need to "warm" up sometimes and does have some smoke on some starts. If i figure out a fix I'll post it here. cold weather always makes me procrastinate working on the car.
Try cycling the fuel pump 4-5 times before cranking. If you have a drain back issue it would cause that problem after it sits over night, but not necessarily after a short visit to a store or something.
^Yep. I don't know if you have to do it more than once, but turn your key to the on position and listen for the fuel pump. Wait a couple of seconds until you hear it stop when your pressure is up. Then crank the engine over.
also..possible dripping injector flooding a cylinder when off. Like 07 boss says fuel pump check ball could cause this and also fouled fuel filter. Had the latter 2 on my wifes expedition 5.4.
1 - 9 of 9 Posts
