im currently building a 96 mustang and im goin the twin turbo route. the engine is 349 in. with a well ported set of 289 hipo heads that flow 210 int. and 170 exst. im usin a holley system max intake 70 lb an hr injectors a a1000 fuel pump and msd ignition. i have good internals and my cam is built for a turbo application and is around 570 lift with a 114 lobe separation. the turbo kit is not new and im not sure the brand but it is twin 57mm turbos with a small air to air intercooler im wonderin if anyone has any ideas on what kinda power i will be lookin at puttin to the wheels at around 8 to 16 lbs of boost...any help or advice would be great thanks!:
