1 - 20 of 49 Posts
King of Clubhouse
hey I saw someone talkin about a under drive pully what does that exactly do?
you really should search man, but they lessen the spin of your accesories to rob less power from the engine. Far bettter begginer mods for your car.
get em unless you have a bangin stereo system. they only take 30min to 2 hours, depends on if its your first time doing it or not. or if you know what you are doing.
King of Clubhouse
its my first time lol my cherry =P looks like I'll do it l8r on in the future
ok pm me when you are going to do it. i can give you full instructions
King of Clubhouse
yea i have heard quite a bit about manifold what does that do
the intake manifold is big flat thing on top and ugrading it is just part of flowing more air
intake manifold is vital because lets say it is highly resrictive.. no matter how big of a CAI, or RAM AIR you get, that intake manifold is still restricing the heads flow the same amount = no power. Intake manifold/head/cam = teh sexinez
i was happy with my underdrive pulleys overall, i know dyno wise they ad what 1 or 2 hp but still, i got mine for $50 and easy to install
im thinkin itll be a while before i get underdrive pulleys because of the fact that add minimal power for the price and like sean was implying if you use the alt pulley its gonna put out even lower voltage
much better off saving for intake manifold or heads or somethin..
Yeah this is a good point. It will help you move a little faster but not a ton. Its relieving your engines workload, and usually looks cool too. Headers + Cams ftw or if your kess on the financial scale Intake + Exhaust + Better Gas
are you guys crazy ?? underdrives are cheap and they make a much better buy at this time then an intake , the heads are the major restriction on 5.0s, and until you upgrade the heads the stock intake will work fine. get some underdrives, they'll free up around 8 - 10 horses and the motor will rev much quicker, just DON'T get the race pulleys
King of Clubhouse
Discussion Starter · #16 ·
i have the motor fan =(
by heads you mean headers right? or is that something else
heads and headers are different, your intake bolts to the heads, air flows thru the intake and is mixed with fuel from the injectors and goes into the heads where valves open and let the air and fuel into the combustion chamber where a piston comes up and compresses it and the spark plug ignites it which forces the piston down and produces power, whats left of the combustion gasses flows back thru the exhaust valve in the head and into the headers and out of the exhaust system
King of Clubhouse
Discussion Starter · #18 ·
oooo ok sorry I miss understood so when I start to do stuff to her what should be the first 3 things I do to her besides the Intake
Do heads cam and intake first if you can get the money......a lil under 2500
King of Clubhouse
Discussion Starter · #20 ·
wow that much for heads and cams? wow yeah it wont be awhile im still makin her stable and solid shes comin along though I remember some guy told me I was trying to build rome in a day and I really thought about it and that was one of the smartest things ive ever heard it really made me slow down and relax a little but shes gettin there
would I be able to install them myself or should I have someone else do it like a pro and how much do they run and how much am I gonna tell a diff
1 - 20 of 49 Posts
