1 - 9 of 9 Posts
- TFS 1.7 roller rockers TFS-51400521 with new poly locks, 7/16. used for one summer with under 1000 street miles. Identical in construction to Crane gold series rockers. Nice stuff. - $175
- Ford Racing aluminum drive shaft - SOLD!!!
- MSD 8584 351W distributor with bronze gear only 4 dyno pull and 4 passes. - $175
- ADS Superchip from 1989 Mustang 5.0/5 speed. Will work on mass air 5 speed Mustangs. - $50
- Cam Motion custom grind solid roller, made 702 horsepower at 7200 rpm with 225cc heads on a 425 inch engine. Only 4 dyno pulls and 4 passes. $175
Specs are as follows:
Cam Motion grind number - R2785-2868-10
Core- 3490016
Lash - .024 intake and exhaust
1.6 rocker ratio – intake and exhaust
lobe separation – 110.1 cam degrees
valve overlap – 64.9 crank degrees
IVO – 34.5 degrees BTDC
Centerline – 106.1 ATDC
IVC – 66 ABDC
Duration 280.5 crank degrees
Lobe lift - .47087
Valve lift - .75339
Lobe area – 42.86
EVO – 78.9 BBDC
Centerline - 114.1 BTDC
EVC – 30.4 ATDC
Duration - 289.4 crank degrees
Lobe lift - .45909
Valve lift - .73455
Lobe area – 44.29
[email protected]
$160 for the driveshaft?
the part number is m4602G not J right?
I'm firm at $175 on the driveshaft. The last one I sold a few weeks ago sold in a matter of days at that price and had a bunch of others that were fighting over it as well. $175 is a good deal and this thing is in great shape. The part number is M-4602-G
ok, ill take it still. you take money orders?
I saw the drive shaft this morning. And get on tonight to pm and damn if it isnt already sold.
TTT
Going on Ebay at the end of the week.
1 - 9 of 9 Posts
