are you saying you plan on running 18 lbs of boost on a stock block?
/\what part of the block needs to be upgraded?.....the whole thing......around 2K for an after-market block.....another few thousand to have the setup you want, then another few thousand for the suspension/chasis stiffening etc...
shouldnt you be making more power with a TT kit.....or do you just have it tuned down because of the stock blockYou need to do the bottom end internals. I have a stock block that was punched to a 306 and all new upgraded internals, trick flow top end kit with scorpion 1.6 rollers, 70mm maf, 75mm throttle body 36# injectors twin t3-t4 turbo kit from SS Auto Chrome and I just hit 455.7hp and 510 rwhp
