1 - 12 of 12 Posts
I have a 86 mustang gt and was told the 88 upper and lower intake manifold ports are bigger and would give me a lil more power, should i switch them over? i have the 88 upper and lower intake already and my dads a machinist should i have him do anything to them?
thanks to any help
If your going to go through the work of swaping intakes, at the minimum id go with an explorer intake.
okay thanks for the info you guys! should i have him do anything to my stock set up? he told me he can port and polish them if i wanted he could pretty much do anything any suggestions?
You can pick up a Explorer 5.0 intake for around $100, that would be a big improvement over stock or ported stock intake.
The upper intakes were different. The 86 had a 58mm throttle body opening. In 87 it was enlarged to 63mm. Good to know when porting for a 65mm throttle body. Here are a few different part numbers.
E6SE-9425-C3B
E7ZE-9425-C4B
E7ZE-9425-E4A
E8ZE-9425-E4A
F0ZE-9425-A4A
F0ZE-9425-A5A
The lower intake were pretty much the same from 86-93. The only change was the location of the part number itself and a little surface detail between the injector ports.
E6SE-9K461-D3A
E6SE-9K461-D5A
+1
I got Explorer intake for our 91 GT and works great plus easy swap. Only thing was a bit pain was drilling ACT sensor hole on #5 runner unless you get relocation kit.
1 - 12 of 12 Posts
