1 - 5 of 5 Posts
I recently installed a UPR catted X and have a small leak on the driver side. The bolts are snug and I installed the cone that came with the kit.
Any tips? Should I try installing without the cone?
Start looking for where the leak is coming from exactly? You might not have it seated properly up where the x meets the headers/manifolds. Just because the bolts are snug doesn't mean it won't leak. If you don't have everything seated in the correct manner it will leak.
Still slow.
I removed the cone, pushed the pipe up higher and tightened it up real good. It ALWAYS leaked with that stupid cone till I took it off.
Thanks for the tips guys, reps given. I think I'll try removing it. I am very confident it's seated correctly.
What is that cone for anyway? It doesn't even seem necessary???
Still slow.
I was told some years the exhaust manifolds have different shaped ports. Never ran into that issue though.
1 - 5 of 5 Posts
