1 - 4 of 4 Posts
Sheep Dog
How do I block off a vacuum line, im putting on an egr delete and I need to block off the vacuum lines runnin to it. Thanks!
Proud American
What lines are you talking about? THe ones that go to the DFPE? If so, when you take the EGR tube out, you will see that both those hoses from the DFPE go to the EGR tube.
I believe if you pull the vacuum line off the top of the EGR, the EGR will no longer open, however I had to take mine off when I put the turbos on and I just stuck a bb in the hose and put it back on to be safe.
1 - 4 of 4 Posts
