1 - 3 of 3 Posts
I just put Windsor Jr heads, a TFS Stage 2 Cam & Comp Cams 1.6 Rockers.
I adjust them like normal, hand tighten until the pushrod looses its slack, then half a turn and lock it down.
Then after the motor spins once or twice, the rocker is loose again, and will jiggle if i grab it. Is this normal?
Thanks...
when its on the base circle it should have a lil play yes
Right on. I've never done them before and I'm tripping. I don't wanna f them up and screw myself.
I'm still concerned about the side to side jiggle though...
1 - 3 of 3 Posts
