I found out im having leak issue on my car, everytime i pull out from the garage i notice the build up. I get under the car trying to figure out wheres it coming from, underneathe i figure that it coming from top of the engine. I feel around the valve cover and figured out its the valve cover gasket. From searching around i found out its easier with upper intake removed to do the job. I need help with the sequence?
Is their a certain sequence in bolting back in the valve cover and intake manifold.
Also wanted to confirm is 12-18 ft lbs for intake manifold and 10-13 ft lbs for valve cover are the correct tq settings?
Thanks
Thanks
