1 - 3 of 3 Posts
I have a 29 model A with 83 2.3 T . Can I turn the VAM up or does it have to lay flat . it looks better in the car turned up . THANKS.
I don't thing turning it would make a huge difference... I just don't think the vane weighs enough to throw it off much. If you just want the filter turned up if there's room a 90* bend will work great.
RAT FINK
Up as in straight up and down? As long as the door inside isn't flopping open and staying open when you put it in the position you want it, you should be fine. But, if it is, you can't do it. The door is made out of aluminum so the weight of it might cause it to be stuck open if it's pointing up or closed if it's pointing down.
1 - 3 of 3 Posts
