1 - 13 of 13 Posts
I sat the lower of my victor on the heads and its way off, I know most need milling but geez, I wanted this because i can get a cheap plate kit aswell, but would i be better getting a TFS r non box if so any one got a goodcheap plate kit?
85 GT convertible
Have your heads been milled? As a general rule for every ten thousandths you mill the heads, you need to mill fifteen thousandths off your intake. Check with your engine builder.
Jerry
You'd have to gasket match heads and intake together, as well as possible milling of course. And remember, the roof matters more than the floor
Resident Know-it-all
Swapping intakes might not help your issue. But an R trickflow has longer runners than that Vic. Just depends on what you wanna do. The R has some huge runners which would require some portmatching as has been mentioned.
I'm not worried about port matching.. But let's say if I didn't check the runners an I ran it I no fuel would get in the heads on one side. Which would be better for a street car with my mods?
What would u guys use? I'm about to get the intake milled if imma keep it. How much is this usually cost
Any opinions?
Ryan, how do u like the r on the street?
Sent from my SPH-D700 using AutoGuide.Com Free App
Not trying to answer for him, just giving my 2¢, but completely different motor combo. He's low compression set up for boost. I'm guessing without asking, but I bet his car is kinda turd like until he gets alot of rpm in it.
Discussion Starter · #12 ·
Oh, I think it's between the r intake and victor, or if I can find a rpm 2. Just can't decide
Ya, our combos are not even in the same ball park, and besides my cobra intake on my stock engine i have nothing to compare it to.
The off the line feel..... is okay but id like it to be a little quicker, but im sure thats because of a few reasons, such as my gear ratio, low compression ect..... im sure that a gear change and some boost that will change all that. Like so many others my car is a work in progress
1 - 13 of 13 Posts
