1 - 6 of 6 Posts
On my phone and can't see the vids, what was the MPH and 60's? What tires and mods?
Discussion Starter #3 (Edited)
Its hard to see THE TIME but the one i lost to the s-10 was my best ever run
times were
60ft-1.8140
330ft-5.5212
594ft-7.9982
1/8ET-8.5502 @ 81.51
MODS:UNDER DRIVE PULLEYS,CAI,75MM TB WITH SPACER,LOWER CONRTOL ARMS,410GEARS,31SPLINE MOSERS FORD RACING REAR DIFF. AND O/R PIPE BORLA STINGERS. RUNNING M/T STREETS 235/60/15
the vid where i beat the diesel was actually the t-t run it was like an 8.61.
my best 3 runs are the 8.55,8.56,and a 8.59
Nice times, I'd love to get into the 8.50's someday. Our mods are similar but i know i need more gear than stock. May have to look at the UDP's. Which ones are you running?
What LCA did you go with as well?
Im running J&M LCA's not sure on the UDP they were on the car when i bought it 3 years ago. is yours a manaul trans? if so u will need to go with a taller tire than what im running or slick if u get 410's. im running 11.5 psi and still having trouble hooking. i put a 2 step on but have not been to the track to try it out yet. i forgeot to mention this run is with out pass. side seat, no front sway, and trunk is empty:)
1 - 6 of 6 Posts
