1 - 7 of 7 Posts
So I have a 2010 With the sync system and steering wheel controls like those of the 11-12s. My voice command and phone steering wheel buttons have recently crapped out. It only works every so often. Has this happened to Anyone else? Anyone know of a fix?
Nope. Just the airbag. Two bolts, and it's electrical. Then the buttons slide out and unplug. Install is the reverse.
Are you sure the button is at fault? The Sync system is buggy at times, or it could be your phone/player.
If I go bluetooth, I never have issues playing music. The answer and hangup button on the wheel is slow to respond. If I plug the iphone into USB, it works right about 70% of the time.
Just goin on record in case anyone has the same problem in the future and decides to search it:
Had an epiphany, moved the steering wheel angle up, the button instantly started working. Moved it down, worked again. Well see if this is a permanent fix though.
With that info, I would suggest looking at the clockspring and the wiring to the steering column for a loose pin or a wire that is breaking apart.
1 - 7 of 7 Posts
