1 - 8 of 8 Posts
it says that it will boost my car from 215hp to 319hp witch is about 100hp...Now my mustang is already dynoed at about 300hp so does that mean i will be at about 400hp if i get this kit?
what all is done to your car?
if you have a better flowing top end it might actually give you more than 100 horsepower
cam,rockers,ported head,upper and lower intake manifold,intake,70mm throttle body,shorty headers full exhaust,4:10s,smog pump eliminator....
what intake what cam
your probably around 300 at the flywheel and a v2sq with about 8lbs of boost should put you around 400-450 hp.I would bore the block .030 and get a diff set of pistons though.
Well, with a stock 302 block, and maximum "leanage" it'll provide about 412 rwhp. I have the V4 S-Trim SQ 12LB version and it boosted my Cobra motor up to 518 rwhp. I could've gone higher, but that would require some minor mods to the block. ;)
what do you mean mods 2 the block??
1 - 8 of 8 Posts
