1 - 7 of 7 Posts
Well, I've been waiting a long while but its finally time for forced induction. I'm going to be running a v3 si trim with a treadstone intercooler, blowing through a vmp5000 maf.
Moderator
If you have any questions Ive ran 3 different vortechs over the years.
Have you run any big intercoolers up front? Mine barely fits behind the crash bar without having to cut it so that is good. But I had to remove the hood latch support to make it fit. Looks like I'm going to have to fab something up or go with hood pins.
_
90% of people cut the crash bar to fit the IC. The other 10% run a Donathens Racing support bar (me), ha.
Good luck with the build! Your in the right place for the information. Sounds like a solid setup, will hit the stock long blocks potential real quick.
Moderator
My intercooler is 31x12x4. It takes some fabrication but it fits perfectlyand i have a modified foam insert as well.
1 - 7 of 7 Posts
