1 - 6 of 6 Posts
got the car dyno'd and not happy with results, but the car hesitates at low rpms, such as starting from a stop light and up a bit, then i can punch it without problems. my list is below, and i dont know what is wrong. i was told i have an exhaust leak, and that's getting fixed when i get my LT's, but could that have made such a difference and caused the hesitation? I doubt it's slippage, I'm not going wot from a dead stop.
99 3.8 mustang with a v1.
36lb injectors, 310lph fuel pump, 90mm lightning mafs, 3.60 pulley, stage 2 power pack.
no codes yet, no vacuum leaks, i've had too many problems with that, so i check that everytime something is done to the car, and smoke? theres black smoke out of the exhaust, but it's supposed to be running rich, so i dont think much of it.
if you can see the smoke your running to rich
you should get a wideband a/f see where your a/f is at
if you were tuned they shoulda left you with abotu 11.8-12:1 a/f area
11.6 to be a little safer
but you wont see black smoke
engine's being sold or parted out. oil pressure dropped to under 40 and I'm not screwing with it anymore. ill post for sale ads later. thanks for all your help with the 3.8!
Why dude
Fix it
1 - 6 of 6 Posts
