If I understand what you are asking...
The only way to make it boost quicker or lower in the RPM range is to either put a small blower pulley on or a big crank pulley. That way it'll be spinning a lot faster at lower rpms. The drawback is that you'll also be spinning it a lot faster at higher rpms, risking damage to your motor if you don't have the internals to handle that much boost.
The only way to have "instant boost" is to buy a pd blower.
