1 - 11 of 11 Posts
Brent from Driveshaft Specialists out of San Antonio, TX wrote me back saying they could build a performer aluminum driveshaft with new trans yoke and flange for $442. You can refuse the $82 yoke and flange but he needs to have your original ones so he can perform the hi-speed balancing. I orginally asked about my 01 Cobra. I also asked about carbon fiber ones out of curiosity but the jury is still out on that. Check them out.
Home Page (Driveshaft Specialists)
It's in the details Mod!
There is a place local here on Atlantas southside that told me they would build me one. They are supposed to be getting me a price, I will post it once I find out if it is a better deal. Thanks for the lead though.
just get a solid axle and add a Gt driveshaft on. cheaper and u get a sra
Depends on what you want to do. Me, I am not a drag racer. I am also not an open track racer. I used to do all that stuff, but not in this convertible. Mine is a mall cruiser. I like the way it handles and rides through the city and highways. If I was a serious drag racer, I would probably swap out the IRS to sn SRA.
OP, are you following the post on SVTP? The FRPP J shaft is supposed to be a direct fit!
Old timer
When my buddy had his cobra he just bought a SRA driveshaft and changed out the pinion flange and it worked fine.
Discussion Starter #10
yeah I wouldn't rock the solid axle idea. A few people I know keep wanting me to do it but I could care less, I don't drag hardcore at least not enough for a solid. Figured at least I know someone who makes a good aluminum axle and it's not made by FRPP since some of their stuff is questionable IMO. Making the Cobra a little lighter for when my Dad tries to run his C6 against me!
2009 ROTY
guess i am a little backwards... i ditched my alumninum one when the ends wore out and went to a smaller diameter steel one. got to ditch the spacer used to make the cobra shaft work with my SRA. i guess the 1.50 60' times were hard on the aluminum ends on the aluminum shaft. :D
btw- only gained 1lb in the trasition to the steel one... car feels firmer and has less noise with the steel one....
1 - 11 of 11 Posts
