i have an 89 notch im putting a carb'd 302 in
well the engine is in need of rebuild so i was wondering
while doin the rebuild what should i do now before the engine goes in the car?
for now the plans are basicly a stock rebuild along with .03 over bore to make it a 306 (need's bored and honed bad so why not go .030 over)
im doing this on a tight budget so the cheaper the better so far
i plan to order a summit rebuild/ring kit (all the bearings gaskets rings and everything needed for the rebuild)
any recomendation on a cheap set of pistons
also i'd like to throw a mild cam in it while im in there
there a good cheap cam out there that i can run on a basicly stock engine and heads (just bored .030 over, headers,600cfm carb maybe an aluminum intake if i can find one for cheap as well)
also from what i understand the carb'd 302 is factory rated at like 180hp 260ft-lbs? i'd like to make 220-250crank hp and say 300ft-lbs is that a reasonable goal? (about the same power output of a stock fuel injected 5.0)
car is just going to be used for a daily and maybe a couple laps around the road course from time to time
