1 - 2 of 2 Posts
when i turn on the car the wideband innovate A/F gauge spools up to 14.9 and sits there until i tap the gas then it just skips up to 22.4 and sits there and doesnt move at all no matter if i drive give it gas it doesnt move one way or the other. it was working fine for almost a week since i picked it up after installing SC and gauges. i cant find any loose wires or anything. any ideas what this could be?
I would start by unplugging the sensor and seeing what it displays. Most widebands will display ~14.7 on startup during warm up. If you unplug it and it reads 22.4 then its probably a problem with the sensor or wiring to the sensor. If it displays something else it may be the control module. If you pull the sensor out you can shoot butane from a bic lighter (without lighting it) at the sensor holes and it will go to full rich. Blow on the tip to get the butane out and it should go full lean.
1 - 2 of 2 Posts
