1 - 7 of 7 Posts
so I bought all the parts to do a 5 lug conversion in my fox, used sn95 spindles and axles. I bought my first set of weld prostars and my question is whether I will need hubcentric rings or not. The hub on the spindle measures about 68mm and the center hole of the prostar measures about 78mm with the center cap in. Can anyone who uses prostars help me out? thanks guys. Also do I NEED 3" studs with a 5/16" wheel spacer?
Need 3 inch studs to be track legal...
and I don't use a hubcentric ring.... infact have no clue what it is.
a hubcentric ring centers the wheel to the hub in the case that the lug studs are a noticeably smaller diameter than the stud holes in the wheel.
RaceStar wheels require a hubcentric ring.
Proud American
yea i have the shank lugs, thanks guys i guess it wont hurt to put the rings on, better to be on the safe side.. also does anyone have a link for the right 3" studs? i dont know what knurl size i need (I dont know what knurl is lol) thanks for the help
thanks
1 - 7 of 7 Posts
