1 - 3 of 3 Posts
So I bought all the parts to do a 5 lug conversion in my fox, used sn95 spindles and axles. I bought my first set of weld prostars and my question is whether I will need hubcentric rings or not. The hub on the spindle measures about 68mm and the center hole of the prostar measures about 78mm with the center cap in. Can anyone who uses prostars help me out? thanks guys.
Also do I NEED 3" studs with a 5/16" wheel spacer? or will the stock length studs be enough. I have long shank lugs
Make sure the wheels arent too wide, you may have to tub it out.
they arn't too wide, 15x8 in the rear, 275/60/15
1 - 3 of 3 Posts
