1 - 19 of 19 Posts
Best Buy Autotech
Lol that's how I am.. when I break something its a good excuse to upgrade.. good luck getting her back on the road bro
thanks man... plans were to do a completely forged bottom end with crank but I think Im just going with rods and pistons, stock crank, and put some money towards cams and a port job for the heads.... even with the blower if I get to the point where that set up isn't enough Id rather build a complete separate block to swap in like a Teksid or something... My motor was surprisingly really clean... It only has 82xxx miles... So I think that set up will do what I need it to
Stock crank will hold a lot of power. It'll save you some money to skip it. It's the pistons and rods you really need.
Best Buy Autotech
Sweet that's what I like to hear... anyone know of a good gasket set? I keep seeing everyone offer the felpro kits for like 275-300... Anyone ever use felpro?
Were y'all not running a fuel pressure safety switch?
Because it cost to much compared to an engine! Sorry OP I suck at humor online.
Be sure to correct the tune issue before you crank on whatever engine you go with. Even a forged piston engine can be damaged with detonation. I have had very good luck with a MMR engine but have heard bad things about MMR also. So far so good with lots of boost (20+ psi) on mine with a conservative tune and knock detection (J&S safeguard).
Best Buy Autotech
Discussion Starter · #11 ·
yes Im getting a wideband, and then Im getting an actual tune instead of a mail tune...
Best Buy Autotech
Discussion Starter · #13 ·
I thought the GT cranks were only good to like 400-450 saftly?
everything I've read is stock cranks are dependable for 600-700, its the rods and pistons that take a **** at 450
damn well when I was looking into the turbo idea I was told id be restricted to 450 if it was a DD do to the crank.. hmmm that could change my rotating assmbly idea if thats correct!
The Mean Green
Stock crank will hold 450hp just fine. But if you can spare the extra few hundred bucks, Id get a forged one anyway.... might as well since your in there, never know when your gunna want more power :3gears
^ This. It's not hugely expensive for a forged crank. Might as well do it if your block is all torn apart anyway. But, yeah, not needed unless you're pushing big power.
1 - 19 of 19 Posts
