1 - 3 of 3 Posts
So I heard back from the machine shop that I took my motor too... I guess the trust bearing head a lot of wear that cause the crank to move back and forth a lot? but other then that he said the crank was fine and will just need polishing, he said usually the crank gets messed up but surprisingly my look fine...... the bearing were wore but not doing any damage to the crank..
I it will need to be bored... I'm buying the pistins and bearings and dropping off to the machine shop, so since LMR had the Mahle forged piston set half off, I ordered that - https://lmr.com/item/M6108X302D/mustang-mahle-forged-pistons-30-over-m-6108-x302d
he said I need standard size bearings... so what brand should I go with? Clevitte 77 Bearings? or is there something better? this will be a pretty much stock motor, just puttong on gt40p heads and ford e303 cam...
1 - 3 of 3 Posts
