the speedo to jump around when your are driving?
depends on the speed..cuz right now my car is a little screwy thanks to timings off and theres a small vaccum leak..it wont spin in 1st gear...and the speedo reads right at that point then i shift into 2nd and it jumps to like 80mph when i'd be lucky to be doing 30mph cuz the tires are spinning.but if its doing it at the higher speeds, when ur are deffinatly not spinning, then its probably the speedo gear or the gauge cluster is busted..That is possible...![]()
this is what i said..last like 5 words of my ****ing paragraph up ^^ therecould be the actual spedo starting to go
didn't feel like reading it...this is what i said..last like 5 words of my ****ing paragraph up ^^ there
idk even remember why i wrote it or what it was about...i just know i said what you said.didn't feel like reading it...
mine jumped around pretty bad when i first got the car but since ive been driving it it only does it under 30mph, id say take the speedo cable out and lube the **** outa itthe speedo to jump around when your are driving?
