1 - 3 of 3 Posts
What cylinders would be most ideal when bringing to TDC for degreeing? Also should I keep followers but one out while degreeing?
a.k.a. Racecougar
As long as you check one cylinder on each bank, it doesn't technically matter which ones you choose. Typically, most people use cyl's 1 and 5. As far as the followers go, yes, it wouldn't hurt to only have them installed on the cylinder that you're using to degree the cam.
1 - 3 of 3 Posts
