1 - 12 of 12 Posts
That Regular Guy
Did you rub alcohol on it?
That Regular Guy
well the only time that happens is when there is a chemical reaction between the paint and something else. So, coulda been the promoter. personally. i wouldn't use the promoter second time around. I've never used it and ive always had good results. start small though.
hmm, most of the write ups i see say to use the adhesion promoter, maybe it was the paint.
Im going to try a different silver on a small area and see what happens
could cold temps have this effect? it wasnt all that warm out when i did this
i had the same problem and funny thing it was the same piece lol...but anyways it happend about 3 times and i have never ever had a problem with painting anything. So i deicided to spray very light coats a few times till it covered everything, then gave it a final coat.
YES! the temperature and humidity can completely **** a an otherwise good paint job... Been there and done that...
Paint on a sunny and dry day if you can. And it wouldn't hurt to warm up the trim pieces with a hairdryer or something of that sort before spraying.
Like stated before though, Id recommend just sanding, then painting (no adhesion promoter), then clearing
thats not from the primer! i use that stuff all the time. insted of useing alchohol use ''prep-all'' wax and grease remover. i'd say their was something still on the part that it reacted with. even the oils from your hands would do that.
Zippy's Resident Milf
Disturbin' The Peace
^ basic plan of attack for painting anything.
1 - 12 of 12 Posts
