1 - 16 of 16 Posts
MM Addict
Alright i put together a rough estimate for a build, keep in mind some of the prices i listed would be if i payed full brand new price for them. what im really wanting to know is what do u think id be able to run in a 1/4 mile Please correct me if i made a bad combination but here i start lol.
1993 5.0 Mustang Lx
Exhaust:
FlowTech Long Tube Headers: $150.00
Jegs Deep Tone Mufflers: $60.00
Chrome Turn Downs : $ 20.00
BBK H Pipe or X pipe : $200.00
Engine:
Gt40 Heads: $400.00
Gt40 Intake: $200.00
Anderson Power Pipe 3.5'' or 4'' : $240.00
ECam: $200.00
BBK Fuel Rail : $200.00
BBK Fuel Pressure Regulator: $100.00
24IB Fuel Injectors
75mm BBK Throttlebody : $220.00
Pro-M 80mm Air Meter and Filter : $250.00
75-100 shot of nitrous :$300-400
10 gallon Fuel cell in hatch: $200.00
Battery Relocation in hatch: Free
Back Seats removed : Free
Front Sway Bar Removed: Free
255 fuel pump: $150-200
Tires:
275/60/15 Rear
Gear:
4.10s
Ditch the E cam.
If you plan on spraying all the time I say get an Anderson b31.
Sent from my galaxy s II
Otherwise it looks pretty solid. With a 100 shot of nitrous I'd say it'll make a solid (with the b31 cam) 370-390 to the wheels.
The Flowtech headers use their own h-pipe, other brands won't bolt up without modding.
Also you shouldn't need the bbk fuel rails
Resident Know-it-all
Buy some good bbk headers with the money youll save on the rails and regulator you dont need. Dont go with 4.10's if youre gonna run spray and 1/4 mile. Ditch the fuel cell, use your stock tank, you cant use stock lines and in tank pump with a cell. Keep it simple, a stock tank, lines, and rails will work perfectly with your goals, get a gss340 pump and install kit and be done with your fuel system.
Powered by LSx tears
Thisis along the lines of what's was thinking.....
And if you buy a letter cam, you can make a lamp post out of it after you decide to buy a good cam.
^ burn
1 - 16 of 16 Posts
