1 - 20 of 20 Posts
because it happened to me when i was driving home from school. I pressed overdrive, it turned off (or on?) and i felt the increased load, so i pressed the button again and the load went away, but the light was still flashing. I stopped at the side of the road, turned my car off, and turned it on again. The light isn't flashing anymore, and works fine when i turn o/d off.
So what could that have been?
Genibus Nitito Canus
the bulb that lights it up might be trying to burn out too
April 2012 ROTM
I know that code...blinking OD light = shoulda bought a stick! :D haha jus messin with ya lol last two reply's sound right though.....
if ur worried about it, check the codes and if it isnt throwing any, then dont worry about it
BYAHHHH!
mine says the 2-3 shift too after a few wot 2-3 shifts..idk its cool for me
i worked on a f-150 with a 4.6 the other day that was doing the same thing and it was the shift selinoid in the trans
Is that a costly repair?
:no...given that is your problem the shift solenoid runs $30 bucks from ford-aode.com and takes all of 15 minutes to install. All you need to do is drop the pan, pull the filter off, remove the L shaped connector (i forgot the name), remove a few bolts, yank the old solenoid out, put some vaseline on the 2 orings on the new one, pop it back in place, put everything back together torquing to spec and refill fluid.
BYAHHHH!
huh my still does it too...i need to do it then have ford scan it b.c just saying 2-3 shifts doesn't tell me ****!
BYAHHHH!
Combo Kit
#K6. Fits Ford 4R70W transmissions, 1993 up. You get the #5-4R70W Alto Red Eagle master rebuild kit for 4R70W transmissions. It comes with all Red Eagle clutches and Kolene steels, high performance direct RedEagle PowerPack, the #8 AODE / 4R70W Fairbanks high performance TransAction kit. This TransAction kit includes a newly designed OD servo piston and a no leak performance design 2-3 accumulator piston. Includes steel boost valve and sleeve to replace worn OEM valve. This is the same kit we use in the Interceptor transmissions. Both for $403.00. SAVE $44.00 HERE !, 10.0% OFF
would that be worth getting? comes with shift kit!
Discussion Starter · #15 ·
will things get worse the longer i delay?
i think u will just lose o/d all to gether mine dont work no more the code was the same saying its not shifting from 2 to 3 but it is so i lost o/d all to gether i mite change it out this spring i dont think its a big deal unless u use o/d alot
BYAHHHH!
i think a shift kit, clutch plates, and some other updates on the 4R and your solid.
1 - 20 of 20 Posts
