OK so I am missing the connectors from the P1 to that other tube.
Now you see I have that 2400BA SCT MAF. I don't have that connect they say I need. But its made for one....what do I do?
90 degree, straight, 45 degree, etc Im not sure. It just depends on youre running your pipe BUT as far as making it fit up to the housing and pipe yea youre right.so I need a 90 degree coupler with the size of the pipe on one side and the size of the MAF on the other?
Nice!!oh yeah I am getting the fuel system after x mas. 42lbs injectors and a single GT supercar pump.
ok thanks for that link! I am lookin at them right now. I think the pipes are 3in. I need a 45 from 3in to 3.5in I think. And a 45 for that intake pipe to a 78mm BBK...would what that be a 3.5in coupler?90 degree, straight, 45 degree, etc Im not sure. It just depends on youre running your pipe BUT as far as making it fit up to the housing and pipe yea youre right.
Nice!!
Generally speaking a coupler is straight rather than 90 or 45 so no. If you need a 45, look under the "45 bend" section on the left and then find the right sizing 2", 3", 3" - 3.5"..whatever you need. Same goes for the 90*. If you need one that changes sizes such as a 90 or 45 that goes from 3 to 3.5 itll be under bending reducers. Dont forget vacuum hose as well for your bypass/bov.ok thanks for that link! I am lookin at them right now. I think the pipes are 3in. I need a 45 from 3in to 3.5in I think. And a 45 for that intake pipe to a 78mm BBK...would what that be a 3.5in coupler?
:yes What brand of headers are you going with ?thanks man! I am doing LTs and hp 292 cams next winter so I need to prepare!
