1 - 13 of 13 Posts
· Registered
how much money do you wanna spend and how much power do you wanna make? for a mild 347 you could go with some afr185s or performer rpms or some twisted wedge heads. those heads should make around 350 rwhp with a good custom cam. if you want more power, get a trickflow r heads and intake or afr 205s or the vic jr heads from edelbrock. you can make over 400rwhp with just about any of those heads and a good custom cam.
· Registered
Best bang for the buck are the AFR heads. I have them on my 347 stroker, by far the best in my IMHO.
· Registered
The AFR 185 heads, Trick Flow Stage 2 cam, and the Eddy Performer RPM intake that AFR recommend with their heads should get you in the 380-400rwhp range.
yea right.not with that cam.
· Registered
they are nice heads but how are they the best?
· Registered
All those heads are good, but if I were to put them on a new 347 then I would have them custom ported...makes more sense to me to take care of that before if putting on a custom motor. With a off the shelf head there are always compromises being done and they will never be an exact fit to the motor or cam (custom cam works in the same way) unless they are worked a bit before...just my $.02:D
· Registered
+1000!!! do it right the first time :D
and dude... in my opinion, the 347 stroker is simply an awesome bad a** motor. you don't really hear of too many problems with them (unless you put crappy heads on them :eek:) lol
1 - 13 of 13 Posts
