41 - 52 of 52 Posts
Discussion Starter #44
Have not posted any updates in here. But I swapped out my iron block for an aluminum one to cut weight. Car is a completely different animal now to drive. Over the winter I will be pulling the heads for porting/milling and a cam upgrade. Should clear 400 at the rear wheels next spring all said and done with weight under 2600lbs.
New engine and T56.
Installed :)
Now it is parked for winter.
Discussion Starter #47
Thanks!
Have not done much to it over the winter other than start it occasionally.
Nice weather finally came through so today I pulled the front off the engine to install the new cam setup.
Discussion Starter #48
Completed some more work. Here is a new idle clip after the changes :)
Discussion Starter #52
Thanks guys! It has been a fun car for sure. Picked myself up some New Edge GT rims to run on the car.
Also a little bit of a walk around. Car got dirty before the video, ran in to a random bit of rain on my way home from work...
41 - 52 of 52 Posts
