1 - 12 of 12 Posts
N/A 4v Guru
Have you had the brakes done recently or worked in that area? sounds like it could be the dust shield for the caliper rubbing the rotor. it's stamped thin metal and makes a sound almost identical to that when it rubs. you can check if with the wheel on so it might be worth a look
it only happens when i hit the brakes in drive also if im in reverse or neutral or park it doesnt do it
1 - 12 of 12 Posts
