1 - 20 of 21 Posts
That's the egr coolant tube. There should be one on the back side of the intake in the same spot that connects to the lower intake in the back. It's to cool the egr spacer down with engine coolant but allot of people disconnect this when they disable the egr system.
I still have my EGR but I don't have a spacer
cobra intakes have the egr spacer incorperated into the upper intake.. every other intake out there for these cars requires a seperate egr spacer to be ran with the intake/throttle body to be able to make use of the egr. Also without a spacer some people run into there throttlebodys not being in the right spot for there throttle cable and such so they have to shortin the cables etc
Discussion Starter · #12 ·
Yeah, I kind of enjoyed having it incorporated as I said I don't plan on keeping the EGR on. It's odd someone said its blocked off when the EGR is removed but it's never been removed or tampered with, aside from that line being blocked off since I got the car.
yea thats what I'm saying with my cobra intake I don't need a spacer because I already have an EGR port built on the cobra intake but my question is that if coolant line is blocked off wouldn't it cause damage to the EGR or loose HP.
Id your keeping your egr functional then having the coolant lines hooked up would benefit you slightly where as no having them hooked up with your functional egr would higher in temperature but wouldn't cause any problems.
I personally deleted them on my dd because of swapping intakes/tb's. Reason for that is the fact that with the coolant going through the spacer it corrodes and makes it very difficult to disassemble the tb,egr spacer and upper intake.
1 - 20 of 21 Posts
