1 - 12 of 12 Posts
what kind of plugs would you recommend for 89 coupe with just bolt ons. And also what are the going rates for building a 347 stroker. Anyone no any shops that are trust worthy in the San Antonio area
Autolite 25 (they have a tapered seat)for stock E7 heads, Autolite 3924 (gasketed seat) for most aluminum heads.
Before having a local shop build you a 347, check out FordStrokers.com or Coast High Performance. They both have a good reputation!
i was using the overly pricy e3 plugs that sells for about 6 bucks per piece. then Kevin, aka horsepowerjunkie recommended autolites. i feel no difference between the 2. spend your money wisely and get some autolites for under 2 bucks per plug.
x2
Autolite 3924 for aluminum heads on motor. 3922s for nitrous use.
Sent from my galaxy s II
There's a lot more to building a 347 then just doing the bottom end.
You're gonna need bigger heads/cam/intake/exhaust... As well as good valvetrain, possibly a tranny, rear end etc.
the heads im running will be the trickflow twisted wedge i think they are 202's cam i have not decided, intake i have the trickflow track heat, exhaust will be the jba shorty headers with h-pipe, rear end upgrading to moser axles with some 410's gears asking is that pretty good combo
Exhaust fume addict
Not a bad combo I say go with a custom cam, Ed @ fti seems to be the popular choice. Your intake and shorty headers are leaving power on the table tho(unless you are boosting)
Resident Know-it-all
Thats your valve size. Your port cc is 170 more than likely, which is hard pressed supporting a stroker motor.
Let me fix that for you... While it is a good base for a stroker, some parts need to be changed.
Use Trick Flow As Cast 190cc heads
Trick flow r intake.
Custom camshaft.
Long tubes (1 5/8 primaries is fine as well as 2.5 inch exhaust)
Behind a T5 that should last, so I'd say that's a solid 350-400rwhp depending on how crazy you go with some parts (valvetrain, supporting mods etc)
1 - 12 of 12 Posts
