I have a stock 97 gt. I want to start waking it up. Gears, s/c, and PI swap are out of the question for now so i was wondering what would be better? CAI? Catback exhaust or a tuner?
I like how you put all those stock things in there to make your mods look biggerGears and Bolt ons and you will be spanking some PI cars.
All i have is....
Stock NPI intake and heads
4.10 Gears,Short shifter,Flowmasters -welded in stock cat back,stock 6 cat Gutted H-pipe-stock exhaust manifolds,75MM T-body-Black Powercoated Cold Air,stock MAF, Stock Plenum,Half inch Plenum spacer,Screamin Demon Coil Packs,Taylor 10.4 MM Wires,Grannitelli Tunner Tuned By Me. <<<< Good For 13.8s-14.2s
I like how you put all those stock things in there to make your mods look bigger![]()
probably the best thing ive ever seen you say lmaoOriginally Posted by 4POINT6Gears and Bolt ons and you will be spanking some PI cars.All i have is....Stock NPI intake and heads4.10 Gears,Short shifter,Flowmasters -welded in stock cat back,stock 6 cat Gutted H-pipe-stock exhaust manifolds,75MM T-body-Black Powercoated Cold Air,stock MAF, Stock Plenum,Half inch Plenum spacer,Screamin Demon Coil Packs,Taylor 10.4 MM Wires,Grannitelli Tunner Tuned By Me. <<<< Good For 13.8s-14.2s
Your Right SOO Much Bigger .....What a Joke!
Hmmm, me thinky you can't count.Gears and Bolt ons and you will be spanking some PI cars.
All i have is....
your hood sucksand so does your g/f's 300 Z
Your Maturety level is quite amusing...your hood sucksand so does your g/f's 300 Z
