1 - 11 of 11 Posts
I just recently bought a 302 to replace in my Bronco and im having trouble identifying it. I looked above the starter and it said 3s ette and a m and a S again. it has a grey oil pan and the spark plug holes are smaller than the motor that was in it. things that were different was the coolant tube on intake manifold and has a spout where the oil goes in so its a different valve cover. which are also grey. Im trying to figure out what this motor is i know its a 302 but is not a H.O. another problem i am having is bypassing the smog pump. I cant figure out what belt to use. I was told a 84.5 which was to small and i got a 88.3 which was to big. I am trying to figure what the hell to do. I may be reading the number upside down cause i did not take off the starter to read them but even then dont make since. Im thing its a econoline motor with E7 heads. I was told it was out of a 92 bronco which its irrelevant it wasn't. Please Help!!!! im got to get this thing running tomorrow.:sorry
The code tells all man... I believe its E5TE. E5 would be a 85 block. 3rd character is a T which would be a Truck engine. 4th is a E which is the engine code for engine.
I think its a 85 roller 5.0 from a ford truck.
ok cool it is a fuel injected motor did they have FI motors then and if so im ****ed cause they said came out of a 92 bronco and had 98k miles on it. lol
Is it a short block or long block? Does it have a intake on it? the intake setup decides if it is fuel injected or not. The motor can be used for a carbed or fuel injected car just swap your intake and carb to it.
so the number near the starter is the engine code? good to kno as im wondering what motor i have-
yes thats the code and it is a long block it came with everything except the tranny. wiring harness and all my bronco is a 93 so idk what the deal is.
85 was first year for FI in a 5.0 Bronco and it has the non HO firing order.
was it toilet bowl injection or multi point injection ?
Discussion Starter · #11 ·
im not sure i do know it has e7 heads.
1 - 11 of 11 Posts
