1 - 2 of 2 Posts
Fee Fie Foe Fum
What oil/lube for cam install? Procedure/tips? Old cams already removed but bottom end is together... Cam bearings look perfect..just insight is all im looking for I pretty much know wats up..ive done sbc before..
a.k.a. Racecougar
It'll be awhile between the cam install and actually firing up the engine, correct? If so, I'd recommend any good paste type assembly lube (the thick gray stuff, not the red highly viscous lube). For anyone reading this in the future, the red stuff can be used if the engine will be fired up within five days of installing the cam, and engine oil can be used (since we're talking roller cams here) if it will be fired up immediately after installing the cam.
1 - 2 of 2 Posts
