1 - 3 of 3 Posts
Ok so I have an sct x3 tuner for my 2000 v6 mustang and ive been tweaking the tunes to see whats the best but im not sure i quite understand everything and i wanted to get your opinions on what you think is best to adjust the tunes at...
rear O2's - on or off?
egr - on or off?
spark 0-2000 degrees - can adjust + or - 2 degrees.....not sure what to do
spark 2000-4000 degrees - " "
spark 4000-8000 degrees - " "
WOT air/fuel - can adjust + or - 2 percent intervals
tire revs/mile - can set at 500, 505, 510, 515 etc...
idle speed drive rpms....
idle speed neutral rpms...
low speed fan - 200 degrees
high speed fan - 210 degrees ... +- 2 degree intervals
WOT shift 1-2 - can set at 0,1,2,3,4,5,6,7....mph
WOT shift 2-3 - " "
WOT shift 3-4 - " "
Shift press percent - can adjust +- 5 percent intervals
1-2
2-3
3-4
so basically those are the main ones i would like to get some opinions on...sorry I know there are kind of a lot of them to answer, but any response to these will help...thanks
Okay I pm'ed him...Does any one else have any opinions? Anything can help at this point
1 - 3 of 3 Posts
